Old 03-27-2022, 04:44 PM
jeffro149's Avatar
jeffro149 jeffro149 is offline
Default K321 Governor/Carb Issues? (IHCC 149)
After using my 149 for around 10 years, I have just finished my first rebuild of a K321. I have built several V-8s but this is my first go at a Kohler. Everything has been replaced, minus the cam. I went through the break-in process...new oil, head torque, tappets and carb adjustments.
The engine runs great at low and high idle. At first the engine would bog under load, then I discovered the governor arm was slipping.
After readjusting the governor arm and setting the high idle stop all appeared to be perfect. I mowed for around 15 minutes and the idle suddenly jumped way higher than I set it and the throttle cable would not slow it down. I have checked the linkages/cables and all appears to be the way I originally set them.
Any help will be greatly appreciated.
Old 03-27-2022, 07:20 PM
Did you replace the governor with a new one?
If not, you probably need to now!!
Old 03-28-2022, 07:58 AM
Sounds like a Governor issue.
Old 03-28-2022, 02:30 PM
Billy-O's Avatar
Billy-O Billy-O is online now
The governor arm might have slipped on the shaft that leads to the governor.
Plow blade
#2 Cart
QA36 snowthower
Tags
149, carb problem, governor, high idle, k321
