Old 03-31-2022, 11:54 AM
Ikea6e Ikea6e is offline
Smile Sudden loss of Oil Pressure
If you experienced this in your Briggs Vanguard powered tractor this may be the problem.
Found these pressure regulating pieces in the bottom of the crankcase.
Didn't see an easy way to reinstall them and be sure the plug would not come out again. So, I made a plug from a 7/16 x 20 bolt.
The plug had a mark on it showing how deep it had been in the inserted.
Had to clearance the hole slightly for the 7/16 x 20 tap.
Reassembled and installed with new plug, 32 psi oil pressure now. ;-)
Old 03-31-2022, 01:55 PM
Farmall450's Avatar
Well done.
Old 03-31-2022, 09:29 PM
Thank you,
Hopefully it will be helpful to someone else.
Ike
Old 04-04-2022, 06:01 PM
Ken41's Avatar
Ken41 Ken41 is offline
Thanks for the info. I have a Briggs Vanguard in my 2165.
Old 04-15-2022, 09:35 PM
Hope you don't need to do the same. ;-)
