Dumb question time! How do you measure wheel weights properly? I was going to check around at some local dealers to see if they have any that will fit my 982. I am told that ones off the front of a Farmall will fit the rims of my 982 - is this true? What is the proper way to measure weights if I am fortunate to find any. Since we all know that there is NO chance you will find weights sitting there waiting to be purchased say..."Pick me, pick me, I am what you need!"
It's true MH. The wheel weights fit in the front rims of the Farmall Cub.
Any chance you know how to measure them? Is the outside of the wheel weight the same measurement of the rim on my tractor (just inside the lip or bead)??
YES , Look at the pictures I just putt up in the 1211 and super progress thread. You will be able to see where the weights sit on the wheel.
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
MH
All of my wheel weights fit the wheels against the lip where the valve stem comes thru the wheel. That is the part of the rim that they tighten against. Rims as shown in your picture (26#?) will fit right down into the rim. Heavier weights will extend out past the rim and tire but they still tighten down against the valve stem lip. The heavier weights fit into the lip where the tire bead seats but not with any great pressure. CC 149 001.jpg CC 149 002.jpg CC 149 005.jpg CC 149 006.jpg
Tom CC's - 108, 122, (2)124, 149, 1320 |
Thanks guys! Time to go HUNTING!
not just any farmall front weights. only the farmall cub ones fit there rear properly.
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
