Old 04-18-2022, 01:43 PM
JPWright JPWright is offline
Default Receiver hitch v Cat 0 3 point v sleeve
There has been lots of discussion on sleeve hitches verses Cat 0 3 point. Has anyone had experience with this receiver hitch (Cast Iron Rear Ends $65.00 / ea, PN# CC-07-002) from extrememotorworks? I am asking because I see a number of attachments for UTVs are available (Amazon.com: Black Boar ATV/UTV, Manually Lift and Lower Implements with Handle or Actuate Using a Drill and Socket (66013) : Automotive).
I have the CC hitch and lift on my 100 and a sleeve hitch brinly cultivator and disc. I have a homemade back blade and I am considering making a ripper/trencher. However, I like the idea of keeping the implement level while being raised and lowered.
Do you folks have any thoughts on going for a receiver hitch?
A 122 with weights and a deck for mowing trails.
100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart and snow plowing.
100 with weights for wood hauling.
Rusty functional 102 with rear lift.
Elec Trac E15 for finish mowing.
Old 04-18-2022, 09:25 PM
Farmall450's Avatar
No, but you can get a hitch receiver 3 point adapter and accomplish the same thing (probably with some lift loss).
https://www.farmandfleet.com/product...ler-mover.html
Old 04-28-2022, 08:25 AM
fortyeightjake's Avatar
fortyeightjake fortyeightjake is offline
I wouldn't be comfortable hanging that much weight on the rear housing.
Old 04-30-2022, 07:50 AM
Sergeant's Avatar
Sergeant Sergeant is offline
On My Xtreme 3point On My 2182 I have one of his Cub Cadet Receiver Mount Hitch For 3 Points
I have a Old sleeve Hitch insert In the Hitch which I then Hang a sleeve Hitch 4 suitcase weight bracket from for winter as I don't want to ever take the 3point Plate off the rear of My Tractor
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
Tags
brinly, receiver hitch
