Old 04-18-2022, 05:12 PM
rfedeleo rfedeleo is offline
Default What is this flat metal bar on the mowing deck?
I heard something dragging on the ground today so I took off the mowing deck and on the front bottom there is this metal piece. Do I need it lol? It's all warped and bent out of shape. Is it just reinforcement or does it serve a purpose?
Old 04-18-2022, 05:45 PM
I am guessing it is some sort of Baffle or Shroud, used to create "lift". You can take it off, pound it straight, then re-attach it. Or, take it off and leave it off.
Old 04-18-2022, 10:29 PM
I agree on helping with suction lift, and depending on the thickness, it might also help strengthen the front lip of the deck, as they usually get banged up quite a bit.
Old 04-18-2022, 10:44 PM
Joes454ss Joes454ss is offline
I think it helps keep grass under vs blowing on top of deck
Old 04-18-2022, 10:50 PM
Ozcub's Avatar
Ozcub Ozcub is offline
In my parts manual there are 2 pieces
1 is called Skirt centre
2 is called Skirt RH
Oz
Old 04-18-2022, 10:59 PM
Thanks. It looks like it came off because the bolts broke so I will have to get some new tap screws or something. I guess I'll take it off for now.
Old 04-19-2022, 01:00 AM
cubby102's Avatar
cubby102 cubby102 is offline
Its the baffle. Alot of them have been removed. Also alot of them get complaints about cut quality.
I try to leave them in when I can. Helps with lift
Old 06-18-2025, 08:11 PM
soilsdaddy soilsdaddy is offline
3 years late to the party, and first post. Wondered why clippings were flying up onto me/tractor from under left side of deck...missing skirt baffle.
