This was a Craigslist find, 20 min from home.
It came from the original owner. Original with a dozer blade and 38" timed deck. Looks to be garage kept all its life. Runs and drives, new chana carb and battery. Has an oil leak on one rear axle, couple drops, fluid level is ok. No weather checking on all the tires. I took the dozer blade off and put the deck on, chana carb is giving me a hard time when a load is put on it. I am gonna put on a correct one and see if that makes a difference, it prolly will... Got it for a Lew price.heheh
Nice! Original owner too.
![]() Someone gave me one of those last year, in a basket.
Nice find! I guess the serial number isn't worth bragging about?
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
23566, not a 3 digit.
Those China carbs sure aren’t great. Don’t really see the appeal either, when you could spend just a shade more on a used Carter and a Kohler rebuild kit.
Of course you probably have a whole wall of new-in-box OEM carbs waiting in the wings anyhow
So I put the old carb the PO gave me back on, runs fine now.
Set the low idle and high limit with this fancy tachometer thingy I got for $1.00. New battery cost more than the tachometer thingy... I put a set of wheel bearings on it, much better, steering is not sloppy but I could change a few ball joints The leak seem to stop, But I will prolly end up replacing the seal. Cut the grass today with it. First time I ever used an Original to cut grass, came out nice.
Nice score!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
Nice unit!
Justin |
That’s an awesome find. Nice survivors are the best type of find.
My IH Cub Cadet Collection: (2) Originals (2) 100’s (2) 108’s 102 125 71 72 |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
