Old 04-25-2022, 10:04 PM
Powerman Powerman is offline
Default 1782 starter gear mesh
My starter was just clicking mostly so I ordered a new solenoid but the new solenoid didn't fix it. Turns out the solenoid is trying to engage the starter gear with the flywheel but the teeth are not always meshing so it fails to pull in fully, thus the solenoid contacts don't close to start the starter. Something I'm missing here?
This is the 1782 w/kubota diesel.
Thanks for your help.
Eric
Old 04-26-2022, 07:49 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Question
I'm assuming you are using the original style starter, and not the upgrade gear reduction unit?
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 04-26-2022, 08:11 AM
The tractor is new to me. It has a new looking original style starter.
Old 04-26-2022, 08:33 AM
1711Cub's Avatar
Lightbulb
I would make sure that you are getting full power to the solenoid, and to the starter motor. Could be a case of voltage drop due to dirty connections, high resistance in the safety switch or ignition switch, or a battery that is not healthy. Male sure all grounds are clean. Extra grounds will only help these. The electrical systems in these were not optimum when new, and age just makes it worse.
Old 05-03-2022, 08:16 AM
V30crewcab V30crewcab is offline
make sure the plate the starter bolts to isn't bent.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 05-03-2022, 10:42 AM
Check for vermin in the blower housing, they like to make nest on the starter side.
Remove the plate under the fuel pump and you can looky see in there...
Old 05-04-2022, 11:46 AM
Lew the 1782 is a diesel, no blower housing.
Old 05-04-2022, 05:58 PM
Oh, my bad, still think the vermin are the culprit...
Old 05-26-2022, 10:42 PM
I did the starter upgrade. All is well now.
Old 05-30-2022, 06:12 PM
nice, need to find time to do that to mine. doesn't look real easy.
72 scout
IH 404 tractor
