Old 08-24-2010, 12:20 AM
william1041200's Avatar
Default dual wheels with mower decks?
anyone out there try to span the guage wheels on the mower decks with dual drive wheels?
Old 08-24-2010, 12:30 AM
Darrell Darrell is offline
I seen a Cub at an auction that had duals w/deck. The guy remounted the gauge wheels inside of the inner tires. Not sure how well it worked though ??
Old 08-24-2010, 01:55 AM
Default i was looking at my duals without a deck...
wondered if i spread them wide, if it would help my traction problem and not interfere with deck or freedom between trees.
Old 08-24-2010, 07:59 AM
Have you thought about loading your tires/adding weight?
Old 08-24-2010, 09:52 AM
It will interfere with getting around trees...you'll have a stripe of unmowed grass the width of the dual around every tree. If you are having traction problems, you need more weight, not more tires.
