Old 05-02-2022, 10:05 PM
romans romans is offline
Default Loader advice needed
I have taken possession of a Johnson loader. I want to put the loader on a super cub. I have a 1882 with like 3000 hrs and it has lived a hard life. I would rather find another super cub that isn't quite as beat to death as mine, and I also want 3 point hitch as well. I have all pieces for the loader itself but nothing for mounting it the tractor itself. A lot I don't know and that's why I am calling on those with more experience to help save me some grief. So any do's and don'ts would be greatly appreciated. Questions that I have...
1.) Is there a "best" place to tie the loader frame to the tractor frame?
2.) Should I tie the loader frame to the tractor frame in more than one place?
3.) What does this cross member type bracket generally look like?
4.) How thick of material should I use for brackets attaching loader to tractor?
5.) Since I don't have the tractor, is there a super cub more desirable for this application since I will be shopping anyways?
I am anxious to get things going but since I don't even have the tractor yet I can at least start hoarding materials and start brainstorming.
Thanks,Tim
Old 05-03-2022, 05:53 AM
I like the 72/82 series machines. Here is a pic of my 1772 with a Kwik-Way loader.
Here is the bracket that mounts to the frame. This is a different setup than your Johnson loader but maybe it will help you.
Old 05-03-2022, 11:18 AM
Farmall450's Avatar
Attachment 110295
Attachment 110296
Nice setup. Just needs a rear blade thrown on for ballast.
Old 05-03-2022, 06:34 PM
Sergeant's Avatar
Sergeant Sergeant is offline
That's usually not enough Ballast. I have found you need suitcase weight hanging off the Blade as well to even get close to the right amount of rear Ballast on a 2WD Tractor
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
Old 05-03-2022, 09:06 PM
Farmall450's Avatar
But then you can't use the blade
Unless you bolt it on or something up high. I added 100# to the 3 pt box scraper on my 284 and that seems about right for light loader work. Needs 55 gallons of concrete to really pick stuff up, but on a cub I'd be worried about the hitch releasing itself
Old 05-04-2022, 12:48 AM
Sergeant's Avatar
I could still use My worksaver Blade
Old 05-05-2022, 08:29 AM
Steve N Mi Steve N Mi is offline
You might consider this manual for the Johnson 14 loader, It shows it fitted to a QL Cub Cadet. Maybe some pictures in it showing mounting brackets to give you some ideas.
https://www.walmart.com/ip/Johnson-1...alog/755573634
I once had a Johnson FEL that came with a Sears Suburban lawn tractor. I sold it to a fellow that had a John Deere LT and included the necessary mods in the deal. It was a well made FEL but the Sears 5/8 front spindles were a bit light duty for it. That wouldn't be a problem, on say, an 1872 with 1" spindle and power steering. The QL's have 3/4" spindles but no OEM power steering, power steering is really a plus with a loader.
Old 05-05-2022, 05:26 PM
ATernus ATernus is offline
I have a Johnson on a 147, and rear blade with 72lb of weights off a ZTR bagger kit on the back of it, and 80 lb of suitcase weights riding directly on the sleeve hitch, and that seems to do pretty well to balance it out, with about 220 lbs on the seat. Had a two spool valve on it for the loader when i got it, and changed to a 3 spool to power rear lift as well. Only issue I've had is the hyd cylinder for the rear lift will find the weakest link between it and the blade, and have broken 2 of the cast iron rear lift arms... one is at the blacksmith as we speak being used as a pattern to get one made that should outperform the cast...
Old 05-14-2022, 11:30 PM
Anyone have a thickness of the steel used on the bracket to mount the loader to a tractor?
Thanks
Old 05-14-2022, 11:50 PM
Farmall450's Avatar
He's not kidding about the P/S. I'm taking the #450 blower off my 1811 tomorrow and putting it on my 1862...power steering is a life saver.
