Old 05-09-2022, 08:45 PM
Vertigo1 Vertigo1 is offline
Default 2182 PTO disengages after warm.
Hi, what would I look for when the clutch won't stay engaged after 2-3 minutes of running?
Cools down - starts working again, but only a minute or so.
Gap set correctly.
Whole PTO assembly changed out 2 years ago and working fine until this season.
Wiring looks good. Testing it without the motor started and it will work every time.
Something is getting hot and disengages it.
Any help would be greatly appreciated.
Vertigo1
Cyclops with a serial number just a few from the end of them.
Old 05-09-2022, 08:52 PM
CubDieselFan's Avatar
What kind of PTO is currently installed? Was it new, used? OEM, aftermarket? Really, as much info as you have.
Old 05-09-2022, 09:38 PM
It was an aftermarket clutch sold by ECCPP. Replacement 717-3389.
New battery and negative lead installed recently. New oem pto to deck belt replaced.
Seat and shifter safety's have been bypassed since I owned it.
That's all I can think of now.
Old 05-09-2022, 09:54 PM
Most likely a China made clutch. They are made cheap, not made to last. The last post in this next thread says it all.
https://www.onlycubcadets.net/forum/...highlight=2182
I was on the couch with nothing to do when this thread was started(getting over ankle/knee surgery). I emailed extreme and asked them if their clutches were made in USA or China. No response so I am thinking made in china. I researched the Warner clutches and they are made in USA and not too much more than the china made clutches. Less than 100.00 more. You get what you pay for. I will look tomorrow when I have more time and post that info.
Old 05-10-2022, 07:48 AM
Do you have a DVM or VOM Meter ??
Old 05-10-2022, 08:19 AM
Roland, I do have a Digital Voltmeter.
Old 05-10-2022, 08:25 AM
When the PTO Clutch fails, measure the resistance of the clutch windings. Anything over 10 ohms, will indicate a FAILURE.
Old 05-10-2022, 08:27 AM
Will do. Thanks
Old 05-10-2022, 02:41 PM
All I can say is that I have been very happy with the clutch's that I have purchased from Xtreme.
Tags
2182, cyclops, pto
