Old 05-31-2022, 11:22 PM
SDBOB SDBOB is offline
Default Going to look at a 2082 tomorrow with bad engine
Friend told me he has a 2082 with a bad engine he thinks it's the cam. As the valves arent moving. He said it has a 48" deck only. Is this a good tractor to buy to repair? Any ideas what I should offer? He did replace electric clutch for belt for deck. Not cheap he said. Thanks Bob
Old 06-01-2022, 08:22 AM
The 2082 was built between 1990-1992 and is considered a SGT. It originally came with a Kohler M20-49512 engine in it.
You would have to consider (A) it's a SGT, (B) what the "roller" chassis is worth, and (C) the cost of rebuilding or re-powering the 20HP engine.
Old 06-01-2022, 08:49 AM
Past repairs are a moot point when "it's done blowed up"
That is a small deck, as they can have up to a 60" deck
look close at the plastic front ends as they are not known for holding up well.
Good pictures of it would be beneficial.
When an M18/M20 don't move the valves, most times it is not a "repair" but more of an engine replacement.
M-20's are not easily had, even the m-18s are getting less plentiful.
Some people repower with modern OHV engines but it isn't a $1.00-2.98 situation.
The good thing is they are a nice tractor with power steering.
Old 06-01-2022, 09:37 AM
Thanks guys. He did say it has a rear pto.
Old 06-01-2022, 12:05 PM
Buy it, buy it, buy it.
But, seeing as how it has a rear PTO, He will know what he's got and it will be priced accordingly I'm sure!
Old 06-01-2022, 02:23 PM
He is a good friend. Bought 2 bigger 4wd JD. We ll see. Talked to my local CC dealer John Labuda. He said if no oil leaking as a hole in block it's worth buying.
Old 06-01-2022, 04:09 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
This is a great model. Magnums, while getting more difficult to find are still out there, especially the M18's.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-01-2022, 06:36 PM
Bought it. He just checking with wife. New electric clutch, new starter, new mower belt, and deck good. Tires excellent, and engine does not have a hole or leaks oil. So going back to pick up. The hood front missing. He has another sitting on it. $500.00.
Old 06-01-2022, 08:11 PM
Farmall450's Avatar
It seems you can't beat a Magnum. What the KT series could have been.
My M18s do seem a little fuel hungry.
Old 06-02-2022, 08:28 PM
Havent picked it up yet. Its covered up in an old old barn. When I do I'll get pics. Thanks guys for all the info. I have too many projects,geezz. We were just bs n and he said neighbor had borrowed it when engine stopped. I said you want sell it, he hadn't thought about it. So I made the overture.
