Old 06-01-2022, 07:58 AM
Sergeant's Avatar
Sergeant Sergeant is offline
Default 190-207-100 Cub Cadet Rear Hitch Plate
Anybody Have a Rear Hitch Plate for a 207 3 point Hitch ?
Reason I ask Looking for someone to trace a Pattern of the Holes of that hitch Plate so finsruskw Can turn a standard 3000 series Hitch Plate into a 207 3 Point Hitch Plate
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
Old 06-03-2022, 11:52 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
Like this? On my 3185.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 06-04-2022, 09:10 PM
Sergeant's Avatar
Yes that what were Looking for
Old 06-05-2022, 08:11 AM
MSS7120's Avatar
Let me know what details you need. I"M assuming the cylinder cutout and rock shaft bolt hole positions are what you are primarily interested in. I'm not looking to disassemble my hitch to trace, but it is on the todo list this summer to fix the leaky final drive..
Mark from Minnesota
CC yard cart
Old 06-05-2022, 08:46 AM
Oak Oak is online now
I think he will need the hydro release lever slot position too because it is different on the 365 hitch and original.
Old 06-05-2022, 09:54 AM
This is what I have
Old 06-05-2022, 10:05 PM
Sergeant's Avatar
MSS7120 I Let finsruskw ask the questions as he is the One Fabricating it Better if I stay Out of It
Other Then To show we Need the Placement of the Rocker shaft Bracket Holes The Hydraulic cylinder Cut Out and The Hydraulic cylinder Frame Front Bolt Hole Locations which I used Dark red for
Old 06-05-2022, 10:06 PM
MSS7120's Avatar
I suspect the hydro release hole will be ok. I removed the rear weights I had for a more direct view.
Mark from Minnesota
CC yard cart
Old 06-05-2022, 10:16 PM
MSS7120's Avatar
Please send a PM with your email and I will get you more higher resolution photos.
Edit: I just sent a PM to finsruskw and sergeant. Please respond with your email and I will send you a google link with photos and measurements.
Mark from Minnesota
CC yard cart
Old 06-05-2022, 10:48 PM
Looks like a triangle between the 2 upper center bolts and the top bolt of either support bracket would provide what's needed for the 4 bracket holes as I already have the 2 upper center holes.
Got the pic's!
What's the O.D. of the cylinder?
Is your tape measure sitting on the hutch plate in the one pic?
