Old 06-01-2022, 07:49 PM
Nessmuck's Avatar
Nessmuck Nessmuck is offline
Default 149 w/ Deere front blade, sleeve hitch rear
I want to mod my 149 to run a Deere front blade with power up and power angle. I'd also like to put on a power up sleeve hitch.
I think, with proper plumbing of a 3 way selector valve, I could do it using the original deck valve.
Has anyone done something similar?
I don't plan on mowing with it, or using the front pto.
I generally mount things like the front blade using 2" square receiver hitch stuff, so I can dismount one thing and swap stuff like winches between machines easily.
Old 06-01-2022, 11:03 PM
Farmall450's Avatar
Search this forum w/ google and you'll see a few discussions doing something similar. It's pretty spendy, when I was looking into the various solenoids/manifolds, vs adding more spools to the OEM valve.
The 149 should already have lift for the "power up" function, use a chain and the lift bracket like it would for a IH plow.
