Old 06-06-2022, 08:14 AM
Default 82 Series Steering Wheel
My son-in-law has a 782. The previous owner of this tractor, had a steering wheel "spinner" on the wheel. My son-in-law removed the spinner, and now has found gouges in that wheel of where it was mounted. Is there a way, procedure, and/or product to use, that can be done to remove (or fill in) the gouges, and make it look like new again?
Old 06-06-2022, 12:42 PM
Farmall450's Avatar
I guess you could try a black epoxy.
I think replacing it would be the only way to get a "like new" look.
Old 06-07-2022, 01:25 AM
cubby102's Avatar
cubby102 cubby102 is offline
I have seen people fill with jb weld sand and paint them and ya couldn't tell the difference...
Those peoples skill and patience levels were way higher than mine
