Hello,
Thanks for letting me in. I have 2 of these model mowers my newest one with only 19 hours on it had blown the fuse while sitting in my barn went to more and nothing. Found the blown fuse, put a new one in and it blows instantly with the key off. Removed the harness and checked all the wiring as was recommended by “experts” on you tube. I know I know. Lol. Should’ve pulled my multi-meter out first as that was an undertaking. Anyway as I put it back together I tested for feedback as I plugged each component back in. Turns out it was the engine harness which I didn’t think would work without the key. I opened up the engine harness and checked for damaged wires nothing, put it back together and checked all the components one by one by unplugging them to see if the feedback stopped. Even unhooked the starter, coils, after fuel solenoid etc. still have full voltage feedback. My question is, could it still be the ignition switch because there should not be energy to the motor harness without the key on, or possibly the alternator is shorted, even though with the switch unplugged it is fine with no feedback. Also unplugging the ignition switch there is still feedback from the motor harness so I’m left to think it is probably the alternator/voltage regulator? Thanks in advance this has me stumped. |
Tractor been sitting long enough for little critters to vandalize wiring and make a nest?
You best to have access to a wiring diagram and follow the path from the blown fuse, if possible. There are many XT1s.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
No critters, mowed with it the week before. Had the harness completely out and bare, inspected all the wires. Regaled and wrapped. It’s in the motor harness that causes 12.35 volt feedback
![]() ![]() Well, I found the issue after much thought looking at the wiring diagram. Figure I’d post an update for anyone else that has the issue of a fuse blowing instantly with the key off. The voltage regulator is the culprit. Guessing a diode went, as I have continuity from the input feed to one of the stator legs, Shorting out to the stator chassis. |
