Old 06-20-2022, 08:35 AM
Cadmandu Cadmandu is offline
Default 2072 fuel pump replacement
Hi All,
Do i have to remove the intake manifold to remove the fuel pump. It seems to be under it.
Can you get the blades off of a 60" haban if you drive the mower up a set of car ramps?
thanks
Old 06-20-2022, 10:45 AM
Do I have to remove the intake manifold to remove the fuel pump.
What make of engine is in your 2072 ?
Can you get the blades off of a 60" Haban if you drive the mower up a set of car ramps?
Yes.
Old 06-20-2022, 11:07 AM
Thanks
Its a M20s
Old 06-20-2022, 12:07 PM
You do NOT have to remove the intake manifold to replace the Fuel Pump.
Old 06-20-2022, 04:20 PM
Okay that is good news. If my new one fails what is your opinion on an electric one
Old 06-20-2022, 04:28 PM
Farmall450's Avatar
Meh.
I normally end up "rebuilding" the old one with pieces of the new b/c the bent arm that rides the cam and actuates never seems quite right on the new ones. At least my experience w/ KT17 Series II and M18.
Old 06-20-2022, 04:45 PM
That sounds like good advice.
Old 06-22-2022, 04:46 PM
I can't get to mount bolts for the fuel pump. It looks like you need to remove a bunch of metal shrouds. I have attempted to do this before and the side covers seem to bolted under the engine. Please advise I purchased an oem pump for 40.00
Old 06-22-2022, 05:28 PM
As seen in the Service Manual on page 11.14.....
Old 06-22-2022, 05:41 PM
The fuel pump is not needed on a 2072 as long as you keep the tank about 1/4+ full of fuel. It will gravity feed to the carb. I ran an 1811 for years without a pump and never had an issue.
