Old 07-02-2022, 08:05 PM
jeepjimmy jeepjimmy is offline
Default 104 new puller
Well its time to build a cub puller for my 9 yr old. I have restored many cubs but never built a puller. I have a 104 that we want to use. Nothing crazy. Just for him to learn and have fun!? Any tips. Advice would be great. Our club uses a dead weight steel sled with weight added as needed. Whats the largest rear tires i can fit?
Old 07-27-2022, 09:21 AM
JSlezak83 JSlezak83 is offline
I’m still very much in the learning stage, but I think most of you questions could be answered by your clubs rules.
I run 23x10.5-12 tire, but that’s the biggest my class allows. You’ll probably need wheelie bars. You’ll want to get as much weight as your class allows and figure outplacement to balance the tractor. You’ll want an adjustable hitch to run the highest height that your class allows. I would think you’d want to freshen up the clutch to be sure it doesn’t slip. As well as a fresh tuneup on the engine to ensure it’s running properly. Even guys with 10hp seem to pull well enough in my beginner class. Making the most of the power you have is key.
‘68 124
‘79 1200
‘93 1440
Old 07-27-2022, 01:24 PM
finsruskw finsruskw is online now
Hearing protection comes to mind.
