Old 08-02-2022, 03:03 PM
JPWright JPWright is offline
Question K241 Rebuild
I have been looking at rebuilding a spare K241 with a knock, for several years. It is my favorite engine for my ground engaging equipment. Over the past week or so I have it mostly dissembled. Still working on the flywheel and PTO pulley (waiting on puller from “parts by Jeff”). With the head off I noticed that the piston is one place where there is “knock”. It moves back a forth a lot in the cylinder.
I have contacted a machine shop that is very far behind and would only bore the block and grind and crankshaft if it were taken apart.
My question for the moment is what to do with the main bearings? The manual says they are most always ok.
My second question is what rebuild kit to buy. Does anyone have a favorite vendor?
A 122 with weights and a deck for mowing trails.
100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart and snow plowing.
100 with weights for wood hauling.
Rusty functional 102 with rear lift.
Elec Trac E15 for finish mowing.
Old 08-02-2022, 10:02 PM
athomas's Avatar
athomas athomas is offline
I've rebuilt a few and have not run into any that I needed to replace the main roller brgs. I have purchased most of my rebuild kits on ebay from bakt4kids and have been very satisfied with the parts and they will customize the kit however you need it !
Old 08-03-2022, 08:04 AM
ironman's Avatar
ironman ironman is offline
Rebuild kits....
https://isavetractors.com/by-engine-...e-rebuild-kit/
https://www.ebay.com/sch/i.html?_fro...op=1&_sadis=15
Old 08-05-2022, 02:04 PM
RoseHillFarmIHCC125 RoseHillFarmIHCC125 is offline
I used isavetractors too. Great to work with.
