Old 08-10-2022, 08:52 AM
goonpeden goonpeden is offline
Default 19.9 Onan
Hello Everyone! Got a question about my Onan 19.9 in my 982. Starts right up and idles perfect but after about 2 minutes starts to break up and run very rough then shuts off and won't start. After about 10 minutes fires back up and runs fine then the same thing. I took carb apart and cleaned and switched out coil from another 19.9 I have and still the same thing but not sure if that coil is good or not. Any help will be Greatly Appreciated! Bill
Old 08-10-2022, 09:30 AM
Sounds like a Fuel Delivery problem.
Old 08-10-2022, 10:53 AM
Thanks Roland! I will recheck and reclean the fuel system.
Old 08-11-2022, 08:17 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
If it does it again, remove the fuel cap to ensure that it is venting properly.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 08-11-2022, 09:55 PM
Check the fuel pump too.
Old 08-12-2022, 08:40 AM
Ok! Will check cap. I took fuel pump apart and cleaned, was a small amount of dirt in it but nothing major. Thanks for the help! Will let you know what happens after I check cap.
Old 08-14-2022, 10:36 PM
Thanks 1711 Cub! Drilled a hole in cap and Onan runs fine now! Thanks to everyone that offered me advice! Bill
