Old 08-14-2022, 01:42 PM
Nessmuck's Avatar
Nessmuck Nessmuck is offline
Default Cub 149 Shifter linkage
Hello all.
I am trying to tighten up the slack/ slop in the linkages on the side of the transmission.
I need any helpful information on replacing the pin on one plate that rides in the slot of the other.
I also need to find replacement ends for linkage rod from the lever shaft to the plate.
I replaced the two springs, but they seemed the same as the old, and the slot they are in is not worn.
I also shimmed the shaft between the lock ring and the outer plate.
Still way loose, so more looking found the above parts worn.
Thank you all.
Cub Cadet 149.
Snapper 1650.
Old 09-20-2022, 05:44 AM
SuzukiT350man SuzukiT350man is offline
I’ve been dealing with the same thing, and sadly it’s one of IH’s major flaws with these tractors. I’ve tightened everything up on my 129 and it still has a mind of its own. For a temporary fix (probably permanent) I shoved a piece of fuel line very tightly on the butt end of the speed control lever and tightened the set screw to the spline shaft, and it has a lot of friction when you move the lever, but it doesn’t speed up on its own any more. I’m sorry i wasn’t able to answer your question properly, but there’s a little something for you to try. Been holding up for around a year so far, but it’s obviously like trying to put a band aid on a broken leg.
If zip ties and duct tape doesn’t fix it, something else will. ‘Jerry rigging at its finest’
Old 09-20-2022, 09:13 AM
New ends for the linkage are available from the suppliers listed above.
Check the parts book for proper numbers for your unit.
