Old 09-01-2022, 06:58 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Default 82 series factory style 3 pt questions
I found this image on the web, do I need this piece to attach the lift bar on my 782 to the rockshaft? Where can I get one? And finally, is there a copy of the 3 pt installation manual for an 82 series?
Thanks.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 09-01-2022, 07:06 PM
Farmall450's Avatar
I think it probably uses a clevis pin; that's how the sleeve hitch is ran on the later tractors as well.
I originally thought I'd have to add a lift block for the 1811 or 782, but IH improved the design s.t. only a clevis pin is needed and it is inserted through a clearance hole in the frame.
Old 09-01-2022, 09:15 PM
I dont see that pin in the parts breakdown. the pin that attaches to the lift arm has three holes in it.
the attached image shows the parts for the 3pt from cub.
Old 09-01-2022, 09:35 PM
Looks like a float lockout pin.
Up to 534 and counting...
Old 09-01-2022, 10:19 PM
Radioguy41's Avatar
This is where it's shown as being used. 82 series is different than other WF's which is why I'm looking for specific info. Supposedly the pin that normally connects the rockshaft to the hydraulic cylinder inserts from the frame side but from what I'm surmising the head of that pin would interfere with the lifting bar so the piece shown above replaces that cylinder pin by moving it to the inside thereby eliminating the interference issue. All this is a theory I've put together based on very sparse info available on the Internet so I'm hoping to find something concrete; photos, actual experience, a specific manual, etc.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 09-01-2022, 11:18 PM
#12 in the parts lookup, float lockout pin,flip it one way the cylinder floats, the other it locks the float on the rock shaft.
Old 09-02-2022, 05:34 AM
Aaron has it on his site.
https://www.xtrememotorworks.com/3-P...Cub-Cadet.html
Hey Roland.....this link doesn't work.
https://www.onlycubcadets.net/forum/...ad.php?t=36392
Old 09-02-2022, 06:09 AM
Radioguy41's Avatar
Thanks, that's the Cat 0 3pt, not what the factory originally called a 3pt.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 09-02-2022, 06:15 AM
Radioguy41's Avatar
Here is a copy I found of the instruction sheet. 82 series is different from other WF's.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 09-02-2022, 06:30 AM
Oak:
YUP, that is the OP's link. I have no control over that. I will try and find, a replacement, with a good link.
