Old 10-07-2022, 02:11 AM
SuzukiT350man SuzukiT350man is offline
Default Hydrostatic pump durability discussion
Next project: Kohler command 20 swapping a 129! (maybe)
It’s very rare to hear about a hydro pump giving out on any IH cub, and they don’t seem to wear out on a 16 horse either. I’ve done research on v twin swaps and found everything it needs to work right (flywheel driveshaft adapter, heavier driveshaft, mounting plate, etc) but i’m curious to hear everybody’s experiences with hydro pumps. I would use it to pull a trailer on my property with many hills, and a 3 speed climbs the hills too fast in 1st and creeper gearboxes are hard to find for a reasonable price, so the hydrostat will have to do. So do please tell your stories with hydrostatics, and keep in mind this is just an idea of mine that hasn’t been taken seriously (yet)
Old 10-07-2022, 07:37 AM
The Sundstrand Hydro is rated for 25HP. It is relatively bullet proof. I have towed a 3/4 Ton 4x4 Pickup with almost no issue (loss of traction).
Old 10-07-2022, 08:52 AM
I use the 125 and the 1862 to haul some heavy loads quite often. Mostly
trailer loaded with fire wood. Winter, summer, chained up. Never had a hint
of trouble. Never tried to tow the pickup though.
Ken
Old 10-07-2022, 08:58 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Main thing is not to overheat them, and use the proper fluid and filter in them. I've heard only a small percentage of failed units from either J**n D***e or Cub Cadet units. I'm sure neglect and abuse played a role in their demises.
Like the rest of the machine, they were overbuilt and last for decades.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-07-2022, 02:11 PM
I have a plan for the overheating issues, the fan on the driveshaft isn’t very efficient so i’ll wire 2 12 volt fans to the ignition switch and put them beside the driveshaft. If it’s stupid and it works, it ain’t stupid lol
Old 10-07-2022, 03:16 PM
1711Cub's Avatar
I think the driveshaft fan worked fine, and was reliable. The problem was/is that very few people cleaned the fins of dirt and debris on the hydro unit, so they didn't stay cooled effectively.
Old 10-07-2022, 10:20 PM
I have yet to take apart any garden tractor, Cub or otherwise that was
not 3 inches under goo. Overheating is a maintenance problem, I concur.
Ken
