Old 08-26-2010, 11:18 PM
TEET's Avatar
TEET TEET is offline
Default CC Original Voltage Regulator Question
Hi all,
I've been fiddling with my newly acquired "O" and I'm at the point of trying to fire the engine. It was missing the ignition switch, starter button, and voltage regulator when I got it. I happened to have the proper switch and starter button ...but my only spare VR was from an old 127 which is the 3 terminal style without the "generator" terminal.
Is it possible to use this VR temporarily to try and get this engine running? Where would the extra wire in the harness go, or is it not possible without the 4 terminal VR?
Thanks,
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 08-27-2010, 07:48 AM
Click on this link for Mechanical V/R Data...... V/R
First of all, both V/R's that IH used had a "GEN" terminal. See above link.
YES, you can use the V/R from the 127 for a test. IF the wiring harness is original and not hacked up, then take the Green wire and place it on the B or BAT on the V/R. This should allow you to start and test out the motor.
Old 08-27-2010, 01:28 PM
TEET's Avatar
Thanks Roland,
So I would be putting the green and gray wires both on the "batt" terminal? The harness is still intact and in good condition, and I plan on getting the correct VR eventually...
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 08-27-2010, 01:41 PM
YUP....that is correct.
Old 08-27-2010, 02:11 PM
TEET's Avatar
Thanks Roland! Appreciate it! :biggrin2.gif:
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
