Running Goodyear Terra Tires on my ALL TERRAIN GO ANYWHERE, ANYTIME 1811 grass mower. Sidewalls are literally shedding chunks of rubber. What do you guys think would be the most comparable replacement--Tru Power, Deestone, or??????
Again, this machine goes places turfs won't even think about and I do run the tires loaded. It will never play in the snow or garden, just mow grass. Having said that, the tires can't tear up the grass and they have certainly got to hold on hillsides.
I hear some good things about these John, but I also hear they ain't cheap. I don't think they are made in 23x10.5x12 but they are in 24x12x12 so I'm not sure they will work in your application.
https://www.carlislebrandtires.com/o...il/versa-turf/ Or a set of bankbuster 23* Stones. ![]() https://www.millertire.com/23x10-50-...23-tire-4-ply/
I have a set of Kenda Terra Trac tires on my 1864, I like them better than the Tru Powers that I used to run on my Supers.
https://www.walmart.com/ip/Kenda-K50...Tire/899141362
I have Deestones Ags on my 1711. They work fine, but look small in diameter. I have heard that they run on the small side as compared to the more popular manufacturers. My 782D has Firestones Ags and they are sized more appropriately.
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
My choice are the OTR Fieldmasters. They are the closest ones I've found to the old Carlisle Superlugs. Height and width is true to size unlike the Deestones and they aren't ultra aggressive like the Firestones or Trupowers. I got both sets off ebay.
Those Carlisle Versa Turfs look interesting though. |
I put a pair of MaxAuto Super Lugs on from Amazon. Love these things. As mentioned earlier they run about one size smaller than advertised so go one size larger when ordering.
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
Went with TruPowers.
I want to say my 782 has older Firestones which have held up well.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
![]() Quote:
