Old 12-02-2022, 08:03 AM
farmer52 farmer52 is offline
Default NGK Glow Plug Replacment for 1772 1782 D640
What is the NGK replacement part number for the D640 engine in a 1772 or 1782? Per 1711Cub and his 782D thread the D600 engine takes a Y103V plug.
D600 KB-15951-65510
D640 KB-15694-65510 subs to 65512
Not familiar with the Kubota parts system, are these the same?
Has anyone "upgraded" their 1772 or 1782 with a "hotter" plug? Is the startability of the D640 improved and no need for upgrade?
Thanks for any information.
P.S. I don't own a 1772 or 1782 but plan to search and buy one. Doing my research.
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 12-02-2022, 06:33 PM
CubDieselFan's Avatar
Get a 1572 or a 1772. The plastic is a pain on the 1782.
Old 12-02-2022, 07:50 PM
W4cnv W4cnv is offline
The best Upgrade I’ve made to my 1782 was replacing the starter. I used the gear reduction starter and that was better than the glow plugs which didn’t make difference. Also I changed out the radiator fan with a six blade from a John Deere 322 that made a world of difference in cooling.
Old 12-03-2022, 11:13 AM
Farmall450's Avatar
I need to dig into mine. I had the head off and went through that but still can barely get it to start. Wet test doesn't make a difference, so I don't know where else I could be losing compression unless the cam is shot.
Old 12-03-2022, 10:32 PM
This my yanmar fan on the d640. Makes a significant difference in cooling. I don’t have any pictures of my glow plug set up. I wired in a relay so they get direct voltage from the battery instead of through the key switch.
File Type: jpg 5998C2DB-8C57-475B-8D57-62C6DFEE9286.jpg (25.1 KB, 49 views)
