Hello,
I have a 38 inch mower deck that came with the 782, I am rebuilding. The deck is the original and in fair to good shape. I have taken it apart. I am getting ready to have it powder coated. I have taken the most of the deck apart, I spend the money to powder coat it white, I have a few questions: 1. I need to replace all of the pulleys for the deck. Are the pulleys available? 2. I also need to replace the tension spring (belt tension spring). Is the spring available? 3. What is the best method a rusted nut on the tensioner arm. It is rusted pretty badly. It looks like there is more hardware on the bolt than just a nut. this is the bolt that the spring on the tension arm. 4. The Phillips head bolts in the deck are rusted badly. The heads seem to strip easily. How should I remove them? The powder coater said I could leave them and they will protect the threads when powder coating. Thank you. |
Don't know where there are Phillips Screws. General speaking, you can take a cut off wheel on a Dremel type of tool, and grind a slot into the head, then take an appropriate slotted screw driver and see if you can turn them out. Also see suggestion #3.
Thank you very much. There are 6 Phillips head bolts on the deck that attach the side pulley guards to the deck. They are rusted pretty badly. Here are two pictures. Do you think I could tap them out? I have tried Kroil.
Thank you very much. I learn a lot from this forum. |
I don't know if you have access to a Welding Torch, but I would heat the head of the Phillips screws red hot. Once the cooled down, then try to remove them.
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
By the looks of that deck shell, if you sand blast it, you will be able to see through it.
. Why do you want to take those out? Looks like the nuts came off w/no issues. Are some of them rusted clean off? Knock 'em out with a hammer and replace them. They are not original, the originals were just 5/16" bolts that were spot welded in place. |
Thank you for the help.
If the mower deck survives the cleaning and powder coating process, I plan to rebuild it. I am using Powder Keg in Gluckstadt, Mississippi to clean and powder coat. All they do is powder coat. I hope it will be in good enough shape to rebuild. Also, where would be the best place for purchasing parts? It looks like I am going to need a new idler arm assembly for a IH 38 inch mower deck that came with a 782. The deck's serial number is U320016U116719. Thank you again for all of the advice. |
If it doesn't survive that's a good opportunity to put the proper 44/50" deck or even a 46" GT.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Thank you. Here are pictures of the idler arm. How can I rebuild or should it be replaced? Any help is appreciated.
MTD/Cub Cadet still sells an updated re-engineered part 759-04324B or 703-0118. What was re-engineered is that large pivot bolt is now greaseable in an effort to keep it from seizing up and wearing out.
![]() Now, just the updated pivot bolt is available separately. Part number 738-3005 or 638-04012A.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
