Old 01-05-2023, 06:21 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Default Opinions on V belts
Just wondering what peoples thoughts are on genuine versus aftermarket V belts
My Cub has the belt that does a 90 degree turn and would only ever use genuine but the deck belt genuine or aftermarket , that is the question ?
Oz
Old 01-06-2023, 06:25 AM
farmer52 farmer52 is offline
I use genuine OE belts/parts unless not available.
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 01-06-2023, 07:24 AM
What I do...........is the Mule Drive belt, that bends 90° and twists, I go OEM. The deck belt, that rotates in the same plane, and runs around the pulleys, I buy a good aftermarket belt(s). Haven't had any issues with that policy.
Old 01-06-2023, 10:49 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I always buy OEM belts. Never any issues.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 01-06-2023, 12:33 PM
Whenever I can I always use OEM so that I don't have problems, so far
it has been a good strategy. I help a few folks around here with mowers
and every time someone cheaps out on a belt. They end up spending
more money and frustration in the long run.
Ken
Old 01-06-2023, 09:15 PM
Farmall450's Avatar
I agree that this is the best way to go (besides all OEM, which isn't needed for the deck belt).
Old 01-08-2023, 05:28 PM
Ozcub's Avatar
Got a good price on OEM for both so went that way
Thank you for the advice
Oz
Old 01-12-2023, 06:55 PM
I've had good luck with Gates green belts and V-Belt guys Kevlar belts. Just my 2 cents but I think the most important issue is the condition of you pulleys and bearings. If you have nasty rusty stuff no matter what brand of belt you use is going to fail.
Old 01-13-2023, 05:37 PM
Ozcub's Avatar
Thanks Sam , thought about Gates but no one local stocks them most aftermarket stuff here comes from China and always wonder about quality
Oz
