Old 01-20-2023, 09:36 AM
Default Magnum Governor Gear
Working on a M-20. I have it torn down. I did look in the M18-M20 Service Manual and could not find the data I was looking for.
(A) What is the factory "bore" of the Governor Gear ?
(B) What is the factory pin (shaft) diameter for the Governor Gear ?
The Governor gear seems "sloppy". I don't think that is correct. I don't know if one, or both items, are worn.
Old 01-20-2023, 10:14 AM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Default dimensions
R. Bedell, I gave a look myself , no numbers. If new parts aren't in the mix. I would put a small brass bushing in gear, if there is any meat left. The shaft you can tell if there is wear. If need be make a new one.
Old 01-20-2023, 10:21 AM
Since the gear is Plastic (Composite), I am guessing this would take the wear, as opposed to the steel shaft.
