Old 01-22-2023, 09:34 PM
MitchJ MitchJ is offline
Default Misfire at full throttle K341
Hello, my Kohler K341 in my cub cadet 1650 will misfire at full throttle. It seems like it’s running rich because when it misfires it will belch Black smoke, but I have leaned the main jet back as far as I can so that it still runs at full throttle. Otherwise it runs at idle and mid throttle just fine and has good power. The misfire mostly occurs when I’m pushing snow or doing some heavy work. Any suggestions? Thank you in advance
Old 01-22-2023, 10:43 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Possibly a weak spark.
1. Check, clean, set your contact points,
2. Try a new condenser. (some guys run 2 condensers)
3. Try a new plug wire.
4. Try a new coil.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 01-23-2023, 08:23 AM
Could be your Carburetor is in need of cleaning, rebuilt, and/or adjusting.
Old 01-23-2023, 09:28 AM
mrfred54 mrfred54 is offline
If you don't find any issues with the ignition or carburetor then possible weak valve springs. Had a 147 years ago that would idle perfect up to bout 1/4 throttle but 3/4 to full throttle it would backfire through the carb. Problem was the intake valve spring was very weak and would allow the valve to start floating and not closing tight at full throttle. New springs and lapped the valves and no more backfire
Old 01-23-2023, 06:43 PM
Thanks- the carb is new and very clean- I did check it recently. And it was running perfectly recently- but it may be ignition
Thanks- I will check all of these-
