Old 02-21-2023, 05:38 PM
Cadetpuller Cadetpuller is offline
Default Spread frame repower
I have a 1989 CC 1050 spreadframe. Which to my understanding is essentially a white and yellow 582 with a kohler magnum 10hp.
I also have a source for a K341 that I want to use to repower the 1050. I don't know yet if it is a narrow block or a wide block. From another forum I read it doesn't really matter. If it is a narrow block then I could use a cradle from a 1282 or 1204, and if it a wide block ???? I don't know. Has anyone done this swap on a 582? Will it work?
Thanks Matt
Old 02-22-2023, 10:34 AM
ironman's Avatar
ironman ironman is offline
I can't speak for fitment, but have you considered the facts that:
1. The Magnum is magneto ignition, the K341 is coil & points.
2. The Magnum has internal voltage regulation, the K341 is external.
3. The Magnum is equipped with a starter, the K341 uses a starter/generator for starting and charging.
All wiring issues.
Old 02-22-2023, 11:39 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
ironman....the 1650 used k-341 that had a flywheel driven starter and a stator with a rectifier/regulator. The 169 used a starter/generator.
Queen Of The Quietlines!
Old 02-22-2023, 11:56 AM
Attached are pics of the k341. Can anyone tell me if this has a flywheel driven started or starter/generator? I believe it to be a flywheel driven 1987 k341. As far as having points or internal/external regulator I don't know. Any help would be appreciated. Also still trying to find out if this repower will work.
Old 02-22-2023, 12:11 PM
The K341S-71309 was an engine built for the WW Grainger Company as an aftermarket replacement. It is a 1987 model with an Electric Starter.
Old 02-22-2023, 01:44 PM
ironman's Avatar
I didn't even think of that. I was assuming a 169's K341. I stand corrected, thank you!
Old 02-22-2023, 02:27 PM
DeltaCub's Avatar
Ironman, you just had a brain fart....you know your stuff!
Cadetpuller, that engine will require a great deal of modification to work in a 1050. Also, the crankshaft may be the wrong size for the PTO clutch. Something else too, the oil pan is not one that is used in a typical Cub Cadet.
Old 02-22-2023, 02:52 PM
I'm not worried about the PTO clutch as it will only be used for pulling. Does the K341 share a block with anything that cub cadet did use that I could swap oil pans with?
Old 02-22-2023, 03:09 PM
DeltaCub's Avatar
the block is flanged at the bottom to accommodate a standard oil pan/mounting surface. I suppose you could make something work to mount this engine. the flywheel. however. is not set up to connect a driveshaft.
Old 02-22-2023, 03:13 PM
Thanks for the info. Sounds like something beyond my skill set and budget. I'm just building something for fun, not competition.
