I have a Cub Cadet 107. I need to know how I can remove the tunnel cover? This is not a shot one. The steering wheel console sit on top, 4 bolts hold it on the frame, 2 on each side.
The 107 does NOT have a "tunnel cover".
how do you remove the leaking valves then ,?
Take the Rear End out of the tractor.
Yup you will have to split the tractor. It is actually not as tough as it
sounds. After disconnecting hydro linkages and brake. drive line etc. There is only a few bolts holding the rear end in place. I would leave the wheels on it, that way you can roll it out of the frame. The instructions in the manual are actually pretty good for this. Once out,you will probably find there is more leaking then just a valve. Like the cork gasket for one. None of it is terrible hard. Just takes patience and a a lot of cleaning of course. Enjoy it, that's why we do this. Ken |
Its one of those jobs that can be done quicker than all the time you spend worrying and procrastinating about have long and difficult the task is.
worried about. That was several times ago. Ken |
That was me when I did my 1450 cork gasket and took the sundstrand pump apart to change the seals. Sweated and thought a lot and jumped in. Wasn’t to awful bad.
![]() IHCC original-70-105-124-147-108-1450 running and usable Projects- Original--72-102-123-100-147-1250 |
Can I just lower it enough to get a socket on it with out dropping the rear completely.?
