Old 03-20-2023, 03:33 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default 1862 Steering
I have a new to me 1862 Cub Cadet. Noticed that it turns sharper to the left, less to the right. Did not know what to type in for a search. Maybe some one can tell me how to correct this problem or give me a link that explains how to correct it. Thanks for looking and have a great day.
Bob
Old 03-20-2023, 06:38 PM
kalebevans kalebevans is offline
My 169 was set up like that. I was curious as well, and after looking around on this site it seemed that the consensus was that they were set up that way for ease of maneuverability while mowing, as you're generally trying to get closer to obstacles on the left side of the machine. I set mine up closer to centered, to not have such poor turning the other way, but it didn't seem to make as much difference as I had hoped. I am intrigued by the 'Super-steer axle upgrade,' but haven't wanted to spend the money required.
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original!
Old 03-21-2023, 06:32 AM
beancent beancent is offline
My 2182 also had this problem and I had to adjust the total length at the hydraulic cylinder that attatches to the spindle and the frame.
Old 03-21-2023, 07:30 AM
I have done this a couple of times.
What I do is turn the steering all the way to one side, count the turns (usually 3) to go to the other side. Place the steering wheel at "mid point", then adjust the steering linkage(s) to get the wheels to run straight forward.
Old 03-21-2023, 07:21 PM
Mr Bob's Avatar
Default 1862 steering
Thanks for the info Roland. Will try your method 1st as it seems the easiest.
Just about have this one ready to go to my friends small farm to see how it does. Hopefully it will do OK. My son in law has 2 more 1862's at his home in Maryland to bring home to me. I bought them and he picked them up for me. Guess I went from Cub fever to Cub crazy. Have a great day.
Bob
Old 03-22-2023, 08:22 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Smile
Bob
Join the crowd. I have gone from one to nine in only three years.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 03-22-2023, 02:20 PM
What took you so long??
Old 03-23-2023, 06:35 AM
Roland 1862's have power steering and the steering wheel doesn't stay in the same place. He will need to adjust it at the hydraulic cylinder.
Old 03-23-2023, 07:49 AM
Sorry, I forgot about that.
Old 03-27-2023, 12:04 PM
Mr Bob's Avatar
Thanks to all that posted. The 1862 does have power steering but I think I got it sorted out. Started it up and turned the steering wheel to the left as far as it would go , then turned it to the right as far as it would go counting the turns . Turned 1 and one half turns. Turned the steering wheel back three quarter turns. Shut off tractor. Walked to front of tractor about 20 feet. Wheels were turned off to one side a little. Took bolt off front steering rod. Moved the wheels until they looked straight. Adjusted the steering rod until bolt would slide back in linkage. Tightened it up and i believe it took care of my problem.
Finsruskw, Just getting older and am trying to help pass the time. Thanks to all and have a great day.
Bob
