voltage regulator
Hi, My 123 does not charge . I get 12.7 volts across battery terminals running and non running . Looked at all threads concerning V/R charging problems . In manual states you can adjust the voltage by turning screw inside regulator . Took regulator apart and found no such screws. My regulator is marked p/n 1414 12V . Goggling this part no. states it is a Delco part .no .
Does anyone know if this is the correct V/R for my 123 . |
Suitable replacement
Quickly looked at how much they cost . Most OEM around $80 . found this link . Is this junk , kidding myself , scroll down
http://www.psep.biz/store/briggs_voltage_regulators.htm |
Before you buy a new regulator, temporarily ground the field terminal on the S/G while the engine is running. If you have an ammeter, it should peg to the charge side, and if you have a VOM connected to the battery, the voltage should increase. If this doesn't happen, the problem is probably not the V/R.
Hubman: The IH part number for the 123 V/R is IH-545130-R92.
I suggest that you take that number to your nearest NAPA and get their current equivalent. Myron B
Myron B East Texas Most of of the fleet: Cub Cadets: 2 Orig,70,71,122,123,104,124,126,86,128, 109,800,1200,1250,1450,1650,IH 682,782D,IH 982. Cadets: 76,SO76,80,81,IH 182. RER: 60,75. Elec 95. Trailers: #2, #3, #4, 1200-A,1200-B,1200-C, 2000. IH 1210 P/U, an IH Scout II and an IH Scout 800 to tow 'em with. |
V/R
Yep, or the wiring leading to it. The 1x6/7 series is notorious for wiring deterioration.
Matt,
After only lurking here for a short time, I would like to say you are wonderful asset to this site. You are a walking Cub encyclopedia. Thanks for your willingness to help and offer guidance to those of us who are less fortunate. I always go to your posts first 'cause I know something good is waiting. Rick |
eralbert-
Thanks! I try to give back by sharing all of the things I've learned while I've been into these tractors. I got a lot of help from people when I knew nothing about these machines. |
As Matt says, check the wiring,
Also make sure you have a good ground on the bolt to the terminal with the braided lead attached.(mounting bolt) Also check each wire end at the V/R for a good connection. You might try running a fine piece of sandpaper through the V/r contacts once or twice just in case there is a bit of problem there. Sometimes we get lucky and find a no cost solution. The v/R you have pictured does not have adj screws. The ones that do, have a provision to increase/decrease the spring tension. Most manuf. have eliminated them for 2 reasons, cost & people tend to adjust things with a "golden screwdriver" usually getting adjustment way out of whack. When they are set @ the factory, they are in a controlled temp setting of 72* and the loads/settings are carefully set to specifications of the application. To much charge & the battery will tend to use water and be overcharged To little charge and battery will not have as much cranking amps and or not keep up to loads/demands,both conditions will cause early battery death. |
