Old 04-24-2023, 09:05 AM
Default Valve Covers
On the KT and Magnums, there are two Valve Covers, one for each side. I have wondered about this for some time now. The covers are bigger (longer) than the casting opening in the top of the Jug. Why is that ? Why couldn't one cut the cover back to where it covers the opening and get rid of the excess ?? Seems to would make pulling the covers for valve checking & adjustment a whole lot easier.
See attachment.
Old 04-24-2023, 10:35 PM
Valves are not adjustable,they must be removed and the stems ground to proper clearances.
The covers come off easily.
Old 04-25-2023, 06:49 AM
I am fully aware of that. I have already done the process.
The "size" (or oversize) of these covers, makes no sense or logic to me.
Old 04-25-2023, 08:06 AM
Sorry, I was replying on the cell, which I find difficult to type on, so
I keep replies short.
It is more cost effective to make the covers larger to insure proper cooling airflow around the cylinders, than to make additional
covers to accomplish that same task.
They try to keep as much air around the heads with as little extra "parts" as possible, exiting it all out the front as you know.
Any air escaping is unwanted heat ingested into the air cleaner, as well as under hood heat.
Blaw Blaw Blaw.
Old 04-25-2023, 08:11 AM
Ah, air flow ...!!!
Old 04-25-2023, 06:38 PM
Well, I cut one down and going to see how well it works.
