My 1450 is in need of replacement engine mounts soon as I can see one corner is sagging down when looking at the underside. Looking at the price of the rubber iso mount cost vs the very well made and reasonably cheap solid mount hardware from Jeff, do solid mounts really make the vibration much worse? does swapping out solid mounts cause any problems?
The engine was rebuild by the previous owner and runs quite smooth. I was planning on swapping out the oil pan with a cast iron one and doing the engine mount brace modification at the same time, but if I'm just bolting it straight to the frame is that mod even necessary? |
I have a 1450 also and IMHO, I like the Rubber ISO Mounts. However, it is your tractor, so do as you see fit.
Often times the upper mounts are in good shape, you could cheat and save a "little" by reusing the old uppers on the bottom and source some amazon replacements for the top. I've done this in a bind and it's a more reasonable solution than solid mounts.
Best thing really is to replace with OEM mounts. Yes expensive but when replaced you will be amazed at how smooth it will operate.
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original |
Stick with the rubber isolators...
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
What they said ^
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
Another vote for the rubber mounts. Do it right and it will be good for another 30-50 years. Also a good time to check out the driveshaft and replace any worn parts while you have the engine out.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
yes I was planning on ordering a pair of flex couplers too
