Old 05-06-2023, 11:26 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default Leaking Cork Seal
Yup, I pulled the 1772 out first time for the season to mow the lawn. In its place I found a puddle of hytran. Looking under the tractor it appears to be from the cork seal. While I have replaced one of these seals on my late dad's 1872, it's been years since I did it. Plus my 1772 has a cat 0 3 pt hitch and the axle braces that were designed by Sam. The question is, would it be easier and faster to pull the pump, leaving the rear end in place and replace the seal or pull the whole rear end, split it and replace the seal. Wasn't there some issue about turning the new seal around to get a better seal?
Thanks
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 05-07-2023, 08:13 AM
Yes you can do that. I don't know if it would be easier & faster.
I never heard of that.
Old 05-07-2023, 08:40 AM
ironman's Avatar
ironman ironman is offline
Thanks
The cork seal has three holes, at 3, 6, and 9 o'clock.
I believe I have read discussions here somewhere about rotating it 180 degrees so that the 6' o'clock hole is at the top instead of the bottom.
Perhaps someone else recalls more about that.
Old 05-07-2023, 10:18 AM
FrankF3's Avatar
I thought it was something to do with having better sealing around the drain back holes and that the oil could drain back through the ball bearing instead.
Old 05-07-2023, 10:28 AM
Ambush Ambush is offline
Aren't two of the holes in the cork for the swash bolt heads? The middle hole is the drain back and as long as the hole is in the casting, it won't seal "better" by just putting gasket over it. Or maybe the intent is to force oil through the bearings, but in either case, since the gaskets last for thirty plus years and the bearings even longer, not sure how anyone proved the theory.
Old 05-07-2023, 10:56 AM
Two of the holes are for the swash plate retaining bolts, if so equipped, ( on some models, the swash plate is part of the casting) the third hole is for oil drain back ( also if so equipped) as some models force the oil through the bearing and are not drilled)
Thus, one gasket can fit all variations of castings.
Old 05-09-2023, 11:07 AM
The older hydro's had 2 bolts and a drain back hole so the gasket has 3 small hole to accommodate these. Later hydro's don't have the bolts or the drain back hole. When I replace the cork gasket if the hydro doesn't have the bolts and drain back hole I put the gasket on up side down. The 3 holes just weaken the gasket an make it more likely to rip.
Old 05-09-2023, 11:26 AM
ironman's Avatar
Does it hurt to rotate the gasket on a hydro with the drain back hole?
I'd think the fluid could still return the same as one without the hole.
At least there would be more gasket meat at the bottom where the leaks are most likely to occur.
Old 05-10-2023, 05:51 PM
I don't have the answer to this question, every one I've done didn't have the the hole or the bolts
