Old 05-14-2023, 05:17 PM
Luke Workman Luke Workman is offline
Default IH Cub rear axle capacity
Anyone on here know the weight rating for the IH cub rear ends? (Cast iron housing with aluminum axle tubes). I've been looking around for a while and I can't really find any maximum weight capacity ratings. I know Ford's LGTs were at 1500# and John Deere 318s had a 1200# capacity, but I've never seen a rating for the Cubs.
1982 IH 782 w/ custom diesel and cat 0 hitch
(Soon to be mine-) 1973 Cub 128
42 inch snow blade
46GT mower deck
Brinly sleeve hitch box blade
Old 05-15-2023, 10:09 AM
Farmall450's Avatar
In terms of using a rear lift, etc?
Maybe as a house designed part IH didn't publish this like the purchased parts used in competitor's units.
Old 05-15-2023, 10:15 AM
Yes, as in using a rear lift or ballast. There is a good chance that they didnt rate the axles.
42 inch snow blade
46GT mower deck
Tags
rear axle, rear-end
