Old 05-18-2023, 05:49 PM
Nozzlehead Nozzlehead is offline
Default 782 3 point lift bar
SORRY GANG…left out the 3pt hitch part.
Can anyone please post a pic of a 782 lift bar FOR A 3 POINT HITCH with the overall length? I believe they’re different than the regular sleeve hitch lift bar. Thanks in advance
Old 05-18-2023, 08:36 PM
First, welcome to OCC........
You can simply use a straight bar, using the dimensions in the image. I have been using the straight bar on 782 for 20+ yrs.
Old 05-18-2023, 09:40 PM
That red one is a lift bar for a 582.
Up to 534 and counting...
Old 05-18-2023, 09:43 PM
Farmall450's Avatar
I understand the 782 to use a straight one. Also, I think the smaller hole should be counterbored or sunk for the clevis pin head.
Old 05-18-2023, 09:46 PM
Farmall450's Avatar
Here's what should fit a 1/2 clevis pin.
Old 05-18-2023, 10:11 PM
I need info on the correct one for a 3 point. I’ve got the numbers for the standard sleeve hitch. I believe they’re different
Old 05-19-2023, 06:23 AM
Part Number: 703-0408
Old 05-19-2023, 07:29 AM
Sergeant's Avatar
Sergeant Sergeant is offline
That Bar is for the traditional IH 3point That you use the Brinly hitch on
Are You Looking for That Bar or or the Cat O 3 Point Lift Bar 703-0811 ?
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force
Old 05-19-2023, 09:54 AM
Farmall450's Avatar
He said he wasn't looking for the sleeve hitch one (I know the purists like to call the sleeve hitch/Brinly adapted setup a 3 point, but that was really a misnomer on IH's part by today's standards).
Old 05-19-2023, 11:22 AM
I’m installing the true 3 point set up; not the Brinly sleeve hitch. I gotta come up with the lift bar that runs from the hydraulic link under the tower back to the hitch plate
