Old 06-27-2023, 07:50 PM
zilla24's Avatar
zilla24 zilla24 is offline
Default 1572 Cylinder Compression
Breaking out in a new thread (Thanks Mods) my 1572 project. I have worked through many electrical issues and am now trying to start the engine. First step was to perform a compression test, I pulled the glow plugs and tested each cylinder one at a time.
Results were not favorable:
Cylinder 1: 300
Cylinder 2: 175
Cylinder 3: 250
Help appreciated on steps forward.
CC Tractors: 1650, 1200, 800, 149, 125, 86, 782D, 2072, 1572, Original
Old 06-28-2023, 07:01 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Cold compression checks are not usually favorable. The concerning part is the variation between the cylinders. While one cylinder is low, there should be enough there for the engine to fire up and run, albeit it might be low on power.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-28-2023, 07:12 AM
zilla24's Avatar
I am sure my testing method was well short of ideal conditions, I just wanted to see what I was working with. Engine was cold and I am suspecting the injectors are leaking, I have seen some diesel fuel at the base of injector #1 while cranking it over so definitely an issue there. Could be a return line but I can't tell right now. Would a leaking injector show low compression?
I ran out of time but my next step is to pull the injectors and validate fuel delivery. Really glad the wiring problem is mostly solved now I need to just keep working down the list.
Old 06-28-2023, 07:50 PM
bleoh bleoh is offline
I would check your valve clearances also. My 1572 had several that were way out of spec when I was putting it back in service.
Brian.
Old 06-29-2023, 06:18 AM
zilla24's Avatar
Brian.
Great suggestion, I'll add that to my list. Were you able to locate a manual for the Kubota engine?
Old 06-29-2023, 07:34 AM
1711Cub's Avatar
Lightbulb
All you will need for the cold lash adjustment
http://cubfaq.com/d600valves.html
Old 06-29-2023, 08:49 AM
zilla24's Avatar
Perfect, appreciate this!
Old 07-01-2023, 01:25 PM
Pray-2-miss-rocks Pray-2-miss-rocks is offline
You could also do a leakdown test, that should illuminate where the compression is going.
Old 07-13-2023, 09:11 AM
zilla24's Avatar
Think I’ve solved my compression issue. It’s cheating somewhat but a solid running G5200 with the D600 came up the other day for a price that I couldn’t pass up. Will be transferring engines and picking this issue up in the Kubota this winter so the 1572 can cut some grass this summer. I might start a new thread on the swap if there is interest.
Old 07-13-2023, 06:47 PM
CubDieselFan's Avatar
I would be interested in the swap.
