Old 10-10-2023, 03:45 PM
CubbaCudet CubbaCudet is offline
Default Fan blade flew off? Starts but won't move..eh?
I was using my SLTX 1050 just as I normally do and all of a sudden it stopped moving. It starts up and the mower blades activate, but when I press the forward/reverse peddles nothing happens.
I looked under the tractor and found a ~7" white fan blade.
I'm a handy person when it comes to fixing things but this one stumps me. What does this blade go to and what does it have to do with the tractor not moving? Looks like it sheared off or something.
Any help will be appreciated, thanks.
Old 10-10-2023, 07:24 PM
Ozcub's Avatar
Ozcub Ozcub is offline
That is a cooling fan for the Hydro , where it goes on your mower I do not know , download the parts catalogue from top of forum and that will show you what is what
You are running a bit to much pressure in your front tyres , tops 14psi no more
Oz
Old 10-10-2023, 08:14 PM
Can you explain what you mean by me running a bit to much pressure in my front tires? What does tire pressure have to do with the fan blade coming off? Is there a sensor or something?
Thank you.
Old 10-10-2023, 11:29 PM
Ozcub's Avatar
Thank you.
Absolutely nothing but one of the photos shows your front tyres and the wear pattern indicates slight over pressure
As for the fan download the parts catalogue for your model of tractor and it will show you exactly where your fan belongs
Just to help you out check this out
https://www.cubcadet.com/en_US/conte...4bd49edbaf4f/y
Oz
Old 10-11-2023, 10:53 AM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
cooling fan for hydro tranny.
Old 10-11-2023, 03:56 PM
ironman's Avatar
ironman ironman is offline
That fan (which is trashed) sits on top of the pulley that is belt driven from the engine.
The pulley turns the input shaft to the transmission.
Since you have have no motion the pulley must have come off also.
If you take the battery out and remove the battery tray, you can look right down at the top of the transmission and see where the pulley and fan should be (or should have been)
Old 10-12-2023, 02:44 AM
Ozcub's Avatar
Hey Hey , whatever you do Ironman do not mention the front tyres (lol)
Oz
Old 10-12-2023, 12:59 PM
My guess is that the belt came off and took out the fan.
Tags
fan, fan blade, sltx 1050, stopped running
