Old 10-16-2023, 11:41 AM
weezykid weezykid is offline
Default GT3200 wont turn off with new switch
My future father in law has a GT3200 that he loves and recently the key stopped working. I pulled the switch and opened it up to find some melted plastic and crud. Ordered a new Stens switch and it starts up fine, but will not shut off with the key now.
Was thinking the switch grounded the coil, but not finding a wire from the switch to the coil. Orange/white off "S" goes to the Brake switch which leads to an Orange/Black that leads to the PTO switch which leads to the orange/white to the solenoid.
He has mentioned some issues with the PTO switch not engaging as well intermittently so this all may be tying together now.
Thinking it may be a bad ignition switch I ordered a replacement. Any other ideas where to check? Hate to just start ordering a PTO switch as well as I don't want to just throw parts at it.
Need to see if I can follow the wiring along from the brake switch to the pto and then to the solenoid... Wanted to check with others.
Thanks!
Old 10-16-2023, 12:59 PM
ironman's Avatar
ironman ironman is offline
Assuming you have the correct switch, with the key in off position the magneto gets grounded thru contacts M and G.
Pull the plug off the switch and check to see if you have ground on the G contact of the plug.
You might first check the 25 amp fuse that appears to provide the ground connection to the switch and also the PTO.
Old 10-16-2023, 01:26 PM
Thank you Ironman!!
Concentrating on the wiring too long I completely disregarded the key switch diagram at the bottom...
Going to test this switch to see if it connects the 3 listed.
Picked up a Stens Delta Ignition Switch 430-220 which crossed reference the same as the cub # and it has the same listed pinouts.
Old 10-16-2023, 01:48 PM
This is the ignition switch that is called out on the Cub parts site for a GT3200
925-06119C
IGNITION MODULE SWITCH RMC (MAN PTO BLK)
This part replaces 725-04227.
Many times the "Will fit look a like's" are wired differently internally and they don't work.
Old 10-16-2023, 03:27 PM
I confirmed that the Stens switch is the same replacement..
https://www.stens.com/430-220-ignition-switch
Also confirmed that is is not a switch issue as they are all connected when the switch is in the off position.
So now for a lot of fun tracing wires.....
Old 10-16-2023, 04:06 PM
ironman's Avatar
Do you have a constant steady ground on the green wire of the plug that goes on the "G" terminal of the switch??
Old 10-16-2023, 05:00 PM
Will check that first, unfortunately the tractor is not at my house.. Going to pick it up next time I am there so I can troubleshoot easier. Thank you both for all of your input so far.
Old 10-17-2023, 10:23 AM
Confirmed that there is no ground at the green wire for the switch so I will pick it up this weekend and dig into it.
