I ran across this GT2186 with just over 500 hours for sale. I know it was made in 2004 as I believe that was the only year for this model. 48 inch deck and the seller has another deck as well. Any advice on this model?
BTW, it's been awhile since I have been on this site. I have been messing with bigger tractors, Farmall Cubs, Ford N series tractors, etc. |
They make excellent engine donors for the 82 series Cubs. Nothing else too special about them in my opinion. Not a bad mower if all you need is to cut grass and not too much.
It would only serve as a backup mower and maybe to pull a small lawn trailer. I have plenty of other, bigger tractors to do other chores, blading, scooping, plowing, brush hogging, etc.
X2........
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Series 2000 were a good mid range of mowers , light to medium duty
The 2185 had a Kohler 2 cylinder , that one has an Onan is that correct ? I bought a 2155 in 1998 and a mate now has it and still going strong , the only weak point I ever discovered was the seat mounting points needed a bit of reinforcing as the contact area was tiny and the bouncing up and down started to fracture the metal of the rear panel Oz
My wife says I do not listen , at least I think thats what she said |
![]() Quote:
X3, nothing wrong with it as is, however.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
![]() Quote:
My XT3 GSX, besides mowing, does a nice job with Sleeve Hitch Implements(Johnny Products Lift Upgrade on OEM Sleeve Hitch), a 30-inch Bercomac belt-driven PTO tiller, and it works great with a Johnny Bucket and Johnny Plow. So it can do a lot more than mow the lawn. ![]()
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
I also ran across a 2500 series Cub Cadet with under 400 hours. 44 inch deck, 18 hp Kohler. I'm assuming it's pretty similar to a 2186, maybe a bit older.
The 2500 series started about 2 years after the 2186 came out, and the 1st 2500 series model was the 2518, which came out in 2002. The same year, I bought a Cub 2206 for my wife
![]() BTW T-Mo what do you need a back up for? You and I are already the same we have back-ups for back-ups ![]()
