Old 11-12-2023, 06:18 PM
tabber tabber is offline
Default 551 snowblower gear box bearing removal
Hello everyone,
Still wet behind the ears, have a 551 and the rear gear box bearings have siezed up. I got the housing split apart without damage, but need to figure out how to get the bearings out along with one of the two shafts. I think I can Gomer a fixture to pull the shaft but two outer races are stuck in the housings. Any tips or prayers would be appreciated. Split the case and it was raining brown dust, no good. Gears look useable, bearings no. Another question is are there other bearings that can be used besides the ones that I see of $50 a pop?
Old 11-12-2023, 06:28 PM
Found bearings on Evilbay for $40 so that's better. But if you have a cheaper source would love to hear it.
Old 12-02-2023, 03:16 PM
TheGrinch TheGrinch is offline
6205 is a common bearing, use these pull the inner seals out.
https://www.amazon.com/PGN-6205-2RS-.../dp/B07CDD5FXQ
2072 owner
