Old 11-16-2023, 02:37 PM
gkingbing gkingbing is offline
Default CC 1541 Carb Adjustments
It does not seem like the engine is running smoothly so I attempted to adjust the high and low speed jets on the carb...the position of both jets does not seem to make a difference unless of course they are screwed all the way in...Screwing the out seems to have no effect on the RPMs. What am I doing wrong????? Thanks
Old 11-16-2023, 04:46 PM
Time for a carb cleaning.
Up to 534 and counting...
Old 11-17-2023, 02:05 PM
Cleaning sound like a good idea. This thing is so old that a rebuild may be in order.....I am unable to locate a rebuild kit, or even a carburator for this Walbro WHG601660. Has anyone had success in finding any info on this carb????? Thanks....
Old 11-17-2023, 02:47 PM
bill682 bill682 is offline
Parts lookup shows...
KH-52-853-23 - Carb
KH-25-757-11 - Carb Kit
https://www.cubcadet.com/en_US/conte...c7afe4a8274d/y
Old 11-17-2023, 06:59 PM
If you google the parts remove the KH prefix and use Kohler instead
Kohler 52-853-23
Kohler 25-757-11
Old 11-18-2023, 04:07 PM
Default 1541 Carb
Thanks much for the info......After cleaning the machine runs well but the high speed jet does not adjust as stated in the manual....It could be removed and it wont effect the engine RPM. As well as it runs well I will just leave it alone..Good for a season of plowing.......Keep warm!!!!
Old 11-18-2023, 05:59 PM
Good reading, Use the number on the carb to determine the kit you need.
https://www.onlycubcadets.net/forum/...ad.php?t=58326
Old 11-20-2023, 08:01 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
If it were mine, I'd locate an older Carter/Kohler fully adjustable carb, and ditch that Walbro right in the trash. I've never had a good fixed high speed jet Walbro.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 11-20-2023, 02:26 PM
Default 1541 high speed adjustment
It is supposedly an adjustable carb for main and low speed....A friend that has one says that his does the same thing when trying to adjust the main jet....It just does not adjust as the manual states.......Its not easy to find carbs for old equipment....
