Old 09-01-2010, 07:23 PM
Cam149 Cam149 is offline
Default 149+Qa-42A
I hooked up the Blower to see what it looks like and figure out how(first time). After it was on and i think i had every thing in place it only lifts about 1.5-2 inches off the ground. Is this the standard lift height? If so i will never get this to load on my trailer and may have to fab something to get more lift.
Thanks in advance.
Old 09-01-2010, 07:26 PM
For got the Pic.
Old 09-01-2010, 08:06 PM
aagitch's Avatar
aagitch aagitch is offline
Maybe you don't have the correct lift rod.
Old 09-01-2010, 08:51 PM
I have 2 lift rods. one matches every thing on the 42" Blade and fits perfect its the shorter of the 2. The second rod is longer but matches the control rods for turning the shoot on the blower. I tried using the shorter one it has no chance of fitting. the longer one fits great will let the blower drop for dips ect. It just has no lift. i can pick the blower up another 3-4 inches by hand after the hydro lift stops.
Old 09-02-2010, 09:41 AM
Would setting up like this help? Seems like you'ld get more lift out of it.
http://www.onlycubcadets.net/forum/s...ead.php?t=4616
Hope this helps!
