Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 09-01-2010, 07:56 PM
papaglide's Avatar
Default to float or use downpressure? that is the question
Just double checking my procedures:
when plowing a field? float or use down pressure?
when disking a field? float or use down pressure?
thanks.
WH 417-A
WH B-80
WH 416-8
WH C-165-8
Mike
Old 09-01-2010, 08:06 PM
cadetfarmer cadetfarmer is offline
Default floating down pressure?
papglide;
let the plow float, if adjusted properly, it should go in the ground by itself. Be careful it doesn't go too deep.
put down pressure, (I use weight on the disc, about 30lbs. per gang) on the disc, to make it cut.
If that's not confusing enough I'll think up some more advice.
Cadet Farmer
Old Farmers don't die, they just spade away.
Old 09-01-2010, 09:28 PM
Merk Merk is offline
Plow-float
Disk-float....may need some weight.
Old 09-02-2010, 01:11 AM
papaglide's Avatar
thank you cadetfarmer, not confusing at all!
thank you Merk
WH 417-A
WH B-80
WH 416-8
WH C-165-8
Mike
Old 09-02-2010, 09:02 AM
T-Mo's Avatar
T-Mo T-Mo is offline
:biggrin2.gif:
Old 05-15-2011, 10:04 PM
Mooner's Avatar
Mooner Mooner is offline
I wanted to bring this post back to the top to see if anyone else had any thoughts about down pressure or floating. Hopefully, this rain will stop someday soon and I'll actually get a chance to try out my plow and tiller.
Old 05-15-2011, 10:07 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I don't know how much it has to do with pressure or floating, but the best thing my grandpa told me was to always make sure your plow was "shiny" and clean as possible, no rust, dirt, or grime. Spraying it with Pam was also another good measure to keep the dirt from clumping on it, especially in some moist ground.
Gary
Old 05-16-2011, 09:35 PM
IHinIN IHinIN is offline
Your better off adding weight to your attachments than using down pressure. When you use down pressure, your taking weight off the rear tires of the tractor and can lose traction.
Old 05-21-2011, 06:47 PM
Iowa Farmboy Iowa Farmboy is offline
How do you float a tractor like a super. As when I get going I end up putting down pressure and take the traction away from the tires.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 01-25-2012, 08:55 PM
cubguy's Avatar
cubguy cubguy is offline
A buddy of mine made his lift system out of a linear activator. The activator puts down force on the plow, he seems to do okay.
just my two sense.
Nroakes
Cub Cadet 3206
Allis chalmers B112
One big Green tractor
