I have an LTX1045 and want to put an electric PTO on it. It currently has the manual lever. Can I grab an electric PTO off a LT1045 and put it on the LTX1045 and wire in a switch for it? Is it possible? Is it pretty simple?
I would check into needing to change the deck drive belt too, and possibly some safety sensors from the (manual) PTO lever. You may also not have a strong enough charging system to handle it.
You could compare cranks from both to be certain if you already have the LTX1045 handy and/or review the parts diagrams on CC's site.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
If the LTX1045 has a stack pulley on it you would need to find a transmission drive pulley to go above the Electric PTO. Unless the one on the LT1045 will work.
Cannon |
OK, thanks everyone. You all confirmed that it isn't just a simple swap and will pass on the project.
