i need to get a hydro rebuild kit for my 149, su15 series hydro static transmission, and no one has any available. are these kits that hard to get?
This may be what you're looking for: https://www.ebay.com/itm/18629869390...Bk9SR6yYoa24Yw
I posted a different link earlier but realize it was probably for a different kind of 15 series pump. Please check and verify the above is correct. I have bought from this seller before and was successful in rebuilding my pump except I needed to run to local supplier and obtain the correct size o-ring for the charge pump. Apparently, there were changes in o-ring sizes on the charge pump at some point in time.... I can't remember the correct size but I recall the correct size to be larger.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
my my gasket is different one piece, but everything else looks correct,
The new link is correct. Too bad the shipping is $168 to Canada
And if your trunnion seals are not leaking and look original, don’t disturb them. Even the ones you buy from Cub Cadet are basically cheap grease seals. If I ever have to replace mine again, I’ll machine the bores oversize to a readily available pressure seal. |
I'm sorry....I corrected the link once more on my original post. Please check this link once again and verify.
Even the ones you buy from Cub Cadet are basically cheap grease seals. If I ever have to replace mine again, I’ll machine the bores oversize to a readily available pressure seal.[/QUOTE] There shold be no pressure in the case for the seals to retain. The pressure is in the pistons and cylinders. The seals should only have to deal with oil that flings off the rotating parts. If you have pressure there you have another problem, I would guess a pluged or painted over breather. |
Because of the very small outer diameter compared to the inner diameter it’s a very hard seal to source. If the original is not leaking, it is a far superior seal to what you will get in a new kit. Unless you somehow luck into an original NOS kit. |
There should be no case pressure. The case is not full of oil it has a drain back to the main case for oil that is exausted from the motor pistons or leaks past the motor or pump pistons. If there is pressure bulding up in the case it would either have to be a restricted drain or pluged breather. I've rebuilt 5 or 6 of these using regular C/R seals without any problems with leakage.
I'm just giving my opinion based on twenty eight full time years rebuilding and bench testing hydraulic pumps and motors. Including hundreds of hydrostatic transmissions.
If you know the actual shipping is much cheaper, I'll be glad to pack and send to help you out (at actual cost)
