Old 09-03-2010, 07:32 PM
animal animal is offline
Default deck spindle bearings
Just thought I would pass on some useful info. The bearing part number 473430-R1 crosses to Timken LM11949 Bearing / LM11910 cone which is referenced to as "set 2" by timken. That is how I was able to find them at Autozone and not separate part numbers. Just thought I would save someone an hour of interweb surfing.
Cody
126, QA42, 48 in deck
Old 09-04-2010, 08:12 AM
FWIW.
they are a common outer front wheel bearing on a boat load of G.M cars that were rear wheel drive, going back to the 60's
Old 09-04-2010, 01:29 PM
Yes they were, but autozone could not find them without the timken part number "set 2". Napa and advance auto no longer carry timken around here anymore.
Cody
Old 09-04-2010, 04:58 PM
If you want numbers, here are some alternates
Rock auto has them for $6.35 skf brand.
I'm sure others will vary, some more, some less
Most of these parts jockeys never saw parts look up book or a Holland interchange, just a computer screen.
This might help em out
Cup radius=.0500"; Width=.610"; Standout=.1350"; Outside diameter=1.7810"; Inside diameter=.7500"; Cup length=.4750"; Cone radius=.0500"; Cone
Alternate/OEM Part Number(s): 000-980-15-06, 000-981-59-05, 001-981-09-05KZ, 001-981-59-05, 0019810905, 013-0584-0, 0220305, 03020103, 0317-33-075, 03173375, 051-3848, 0513848, 1-2931, 1-8315, 11055100, 11055109, 11084621, 11084631, 11084641, 11900.21408.00, 11900.21408.01, 129897, 1458BR2, 1516158, 1583111, 1583567, 1615336, 1619689, 1671465, 179080, 181104, 1815845, 181585, 181586, 2-634-103, 2-634-107, 202502C91, 202514C91, 204E1215, 204E1215A1, 204E1215A2, 204E1215A3, 211-405-645-D, 211-405-645B, 211-405-645D, 211405645, 212-10300, 212-10503, 212-10910, 212-12004, 212-19302, 23-12-1-451-158, 2421067, 26784649M, 3027681, 305691, 31 21 1 468 888, 31-21-2-634-103, 320012, 330012, 36C6041, 3744924, 38-00810, 38-04203, 38-99920, 38-99921, 3838020, 385175, 40215A0100, 4176751, 431571, 457478, 471096, 4T-LM11949/LM11910V1, 4T-LM11949V4, 505508, 52-22-508-6, 524157, 52710FD000, 5273036200, 594876R91, 64-00055, 647777M91, 651816R91, 652072R91, 652078R91, 66177V, 682-1075, 70EB1215AA, 7413409, 7450627, 804853R91, 81AB1238AA, 827471C91, 8983453, 8A1215C, 8L03030, 9-801-506, 90368-19037, 9052, 91052-671-004, 91052-671-008, 9192000, 91920000, 9739NO2SET, 999-059-065-00, 999.059.007.00, 999.059.009.00, 99909506500, A-2, A113158Z, A141236Z, A2, A23174, ATA4238, B092-26-075, BR2SKF, BT2S, C15352, CMP2, CS2, D0RY1216A, E0ZZ-7F431A, E7GZ1216A, ET-LM11910, ET-LM11949/LM11910V2, FPSET2, FS2, FSK6151, GHB102, IR2030, K2, KLM11949.LM11910, KLM11949/LM11910, KLM11949KLM11910, KLM11949KLM11910Q, L81-1181, LM11949/10, LM11949/LM11910V1, LM11949910, LM11949LFT/10, LM11949LM11910, LM11949R/910R, LM11949UA/LM11910, M12649/10, MB002073, MB515027, N055100, N055101, NO2SET, P43536, S-2, S2, S302, S5, SET2, SET2-6, U81-3508, WB1004, XJD26039, XM508081, YR17, ZZL0-33-053, ZZL033047
Old 09-04-2010, 10:27 PM
Grasshopper has much to learn.
Cody
