Old 04-24-2024, 09:27 PM
nkramer nkramer is offline
Default what tractor to keep?
Hi everyone, I have been looking for a bigger tractor for mowing and snow removal to replace my john deere 314. I found a gentleman selling two 317s and went to look at them and he also had a cub cadet 2086 not running with a 54 inch deck and bracket and a large 2 stage snowblower, it also has rear 3 point. It has a kawasaki 20hp engine. I offered him 500 bucks and he said yes. I got it running after cleaning the fuel solenoid, it runs and mows really great. Then when i was researching the value of it I found a 2182 for sale close to me with a 54 in deck and a snowblade and i jumped on it. This one has a kubota gas engine. I will try and figure out how to attach pictures but I need some help deciding which tractor I would be better off keeping!? Also any tips and tricks to look out for. I read a little about loose bolts some where and also read about a plastic cam gear on the kawasaki. the 2086 has 1700 hours and the 2182 has 800 hours. Thanks in advance
Old 04-24-2024, 10:54 PM
Farmall450's Avatar
The correct answer is both, but with the low hours I'd probably keep the 2182.
Although the later fender super cubs do look sharp...
Old 04-26-2024, 09:04 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
The WG600 engine is good, but they are thirsty. I would prefer the 2182.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 04-26-2024, 09:11 AM
CubDieselFan's Avatar
I would keep both but if I had to choose and only keep one, I would keep the 2182.
Old 04-27-2024, 02:45 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Kubota makes a very good motor, love the gassers simply so I do not have more plastic jugs around that would need to be yellow
Old 04-27-2024, 06:30 AM
Well thanks everyone, I am just getting some time to get used to these new machines and I noticed the 2182 has very slow reverse, also maybe a little noisy/whiny. Should I just try and swap the valves from tractor to tractor to see if one of the valves is bad, or even swap the same tractors valves to see if the symptoms show up in forward now? Thanks.
Old 04-27-2024, 09:54 AM
1711Cub's Avatar
Lightbulb
Verify proper shifter adjustment, and proper hydro filter and fluid condition and level.
Old 04-27-2024, 07:50 PM
i got it figured out someone had the shift linkage mounted to the top hole of the hydo governer plate and it was barely letting it tilt down for reverse, switched to bottom hole and it is like brand new!
Old 04-28-2024, 12:43 PM
Farmall450's Avatar
Still not a bad idea to change the fluid & filter. Small investment into your new machine.
Old 04-28-2024, 04:30 PM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Good advice. Some of these machines haven't had the hydro touched since new I bet.
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
